2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
Hello,
I'm preparing to put in a new kingpin kit for my 48' 1/2 ton. I've got all the years of grease cleaned and I'm currently soaking all nuts and threads.
I'm planning to remove the tie-rod end from the knuckle, but wasn't sure if I just remove the cotter pin (carpenter nail in mine), and turn the big end screw cap counter clock-wise?
Presuming the ball joint cups will slacken enough to allow me to remove?
Any guidance and corrections are appreciated.
Thanks Steve
1948 1/2 Ton 6-volt 216
A big giant screwdriver with vice grips clamped on were the screwdriver is still flat works pretty good. A little heat from a propane torch will help too.
Well it looks like I now have another excuse to buy another tool! I first put a gasket scrapper on it, which seemed fit pretty good, but no movement.
I'll take your advice with vice grips and a little heat if needed. Thanks
Socket sets used to come with a screwdriver type socket. You might be able to find one of those at a swap meet
It's been ages since I've seen one.
Drag Link Socket
[on edit] Snap-on still sells them.
KLhansen - Thanks for adding the ebay link!! I'll be bidding for sure smile...
May get good leverage with my breaker bar ...
Steve
Don't bid without knowing the size and what size you need.
I collect drag link sockets (when I find them cheap) because every time I need one it is always a different size than what I already have. Even have one that is 3/4" drive, sometimes there is no substitute for the proper tool... I tried a lot of things before buying that one.
•1952 Chevrolet 3800 pickup
---All pictures---
Fox Offline
If it comes off easily, thank the PO for at least adding a little grease somewhere along the way. Mine were always a bear to get off.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I actually found one in my old tools collection, but not quit as wide as needed, because of how tight. I'll pickup a used wider one up.
This poor truck hasn't seen much grease in a long while.
I made one of those sockets out of a large nut and bolt with a welder and an angle grinder. It has a screwdriver blade on one end and a big hex head on the other. I use a socket on a 1/2" air ratchet to back them out.
I think I made one from a cole chisel. It had a hexagon shank that I used a wrench on.
1951 1 Ton Completed
