| | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | 1947 half ton (3100) with stock 16 inch wheels and tires. I have been told the original wheel will work with a 215 x 85R16 tire. Can anybody confirm this? If I wanted to go to a more modern style wheel and tire can anyone make a recommendation? I would only be interested in a wheel that would work with the bolt pattern of the stock front/rear hubs. Thanks, Ray | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I have two 3100s with those tires on stock rims. I did not use inner tubes. I sandblasted, epoxy primed, smeared a bit of 2 part epoxy around the rivets inside of the rims, and painted them. They are a little over 2 inches bigger in diameter which results in minor changes in my shift points, and lowers RPM at highway speed. I like them.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have Cooper Tire SRM II LT215/85R16 black truck radials on my Suburban (they are pretty old, 10+ years).
The 1954 16" rims are 4.5" x 16".
Your 1947/48 rims might be either 4.0" or 4.5".
The mounted tire diameter, as Carl posted, is around 31". The "advertised" diameter is around 28". | | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | Thanks Master Gabster. Sounds like all I need to do is buy the tires. I will probably stick with tubes but I need to find some new ones. The tubes on it now have a very long stem that sticks out more than I like. | | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | bucktruck,
I forget to mention in my post above:
The set of Cooper radial tires on my Suburban have "radial" inner tubes. They also needed a valve stem protector where the valve comes out of the wheel - added by the tire supplier/mounter. No problems ever - 12k highway/Interstate and country-road miles on these 14+ years old tires.
The other set of Goodyear truck radials are on the same type of 1954 wheels, but these wheels were in excellent condition - no stem protectors needed and tubeless. I have not driven on these 4-5 year old tires, but they are holding air.
The trucks/tires mentioned above have been on trucks stored/housed in garages (not parked outside, except on trips). | | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | Guy at a local tire store as me to consider this size (225 x 75R16). He said they would not be quite as high and a little wider than 215 x 85R16. Do you think they would work on the stock 4 to 4.5 inch rims? Thanks, Ray | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Here is a good calculator to determine tire size. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2000 Posts: 2,189 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,189 | Guy at a local tire store as me to consider this size (225 x 75R16). He said they would not be quite as high and a little wider than 215 x 85R16. Do you think they would work on the stock 4 to 4.5 inch rims? Thanks, Ray The tire manufacturer will list rim width range recommendation for a specific tire. E.g. If you were interested in a Kumho Crugen tire, the recommended rim width for a LT225/75R16 is 6" - 7" https://www.kumhotireusa.com/tire-category-sub-detail/light-truck-uhp/all-season/7/crugen%20ht51
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 215/85R16 Radial will work well on a 4.5" wheel/rim.
Think three times before putting a 225 x 75R16 on a standard equipment 1948 4.0" inch rim
| | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | 52 Carl.....How much wider would you say the 215/85R16 tires are vs stock narrow tires? With no tubes would you suggest using valve stem protectors? Thanks, Ray | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | They are skinny looking. No need for stem protectors needed. The tubeless valve stems fit the holes in the stock rims perfectly.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I should have mentioned above that one of my set of wheels needed valve protectors because of the rust/pitting near the holes (on the inner side of the wheels). I have had no problems after many years of use. | | |
