2 members (Hotrod Lincoln, baldeagle), 46 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#13263 07/10/2003 4:23 AM
Can anyone tell me what size of line runs from
the oil pump up to the rockers..Is it steel or
copper...The motor is a 216...thanks
1946 chevy 1/2 ton panel
1937 ford coupe
#13264 07/10/2003 12:58 PM
It's copper and I'm pretty sure it's 1/8". You can get the line with all the fittings from Chevs of the 40's for something like $12.00.
#13265 07/11/2003 3:36 AM
The line won't be going from the oil pump to the rockers. If this is a US engine, it will go from the outside of the block, driver's side, through the block to the side pan cover,and then up to the rocker arm. If this is a Canadian 216 with the short side cover,it will run from the top of the rear cam bearing area across the side cover area and up to the rocker arm. This routing is the same as the 235.
1951 1 Ton Completed
