| | | Forums66 Topics128,019 Posts1,055,343 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | The seat riser in my 1947 (2) is in sad shape - it's rusted, been modified, and is bent pretty good. Anyone know of a source to get another, or do I need to fab something? This is for the stock bench seat..... | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I have seen some really rough looking trucks which were total basket cases except for the seat riser. It seems that they are above the waterline when these trucks are inundated with rain out in the weather. Start combing the hedgerows and older junk yards that haven't crushed everything yet. You will need to bring something to cut the floor outside of the perimeter of the seat riser. A cordless sawzall would work. Bring a couple of batteries. You can then remove all of the spotwelds once you get it home.
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | If there's no yards with old stuff near you, you're a couple hundred miles from Wymore, NE (south of Lincoln). There's a yard there that's full of older vehicles. The address is 2734 E Sage Rd. Take a road trip over there. The owner is probably 80 and a nice guy. You won't be disappointed. Might find something else you need as well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | I have a couple friends in the Steinauer area, maybe I can convince one of them to go.....its only 30 miles or so....Nothing close to me, though. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Mongo might have what you need. He is a member/moderator on this site. Mongo's Garage | | |
