5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#1325857 09/12/2019 2:01 AM
well you know those times when you have one project stalled, one project done, one waiting to start and you're not sure what to do? well that was me, and what did i do? i bought another 1950 3100! hahahah. this one is different I told her, this one is going to run all original. So, that is what I am doing. I have the motor turning and the starter is good, but i seem to have sprung a leak in my oil pan through something like a nail hole. Does anyone know where I can get a replacement oil pan? I have been looking online but perhaps I am not searching the correct terms. Oh, and of course I am not trying to pay 300 plus for an oil pan. you can get these motors complete for that money.
Thanks!
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
Why not just fix the one you've got? It sounds like maybe one of the bolts or rivets holding the dipper troughs to the pan might have gotten loose and fallen out.
I will pull it off and take a look tomorrow. it did seem strange that a hole just appeared.
My Project Bolt
Silverado_9c3 #1325885 09/12/2019 11:42 AM
Check your PM.
Mike
1951 3100 5 window
turns out I had 1/2 a dozen pin or nail sized holes in the pan when all was said and done. I simply welded them all up, leak checked it and reinstalled it with a new gasket. leak free as of yet.
My Project Bolt
Did you check the targeting of the oil pipes when you had the pan off? The troughs only supply oil to the rods at idle. Once the oil pump volume increases at cruise speed, a stream of oil squirts straight across the pan and it must hit the rod dippers as they get close to the bottom of their stroke. It's not uncommon to burn a rod bearing due to lack of lubrication if a nozzle gets bent.
