0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
Hi.Im looking at fitting power steering to my 56 265 small block.I was wondering where to fit the pump on the engine.Has anyone fitted one to a 265 and if so how.Cheers
Just get a factory or after market manual and look at it. 56 came from the factory with power steering with the pump on the rear of the generator. The steering itself was with a ram assist on the tie rod. For an updated version there are p/s units that mount the same as the manual steering box. I prefer the 500 box over the 605 as it gives an easier column hook up. For a non-generator p/s pump mounting there are kits offered or you can make your own using the left front motor mount engine bracket and rear bracing to water pump or exhaust manifold: picture of a 55 265
[img]https://i.postimg.cc/CzdjxBkP/Pete-s-column-and-p-s-pump-004.jpg[/img]
Evan
Check with Alan Grove to see if they have what you need. They make mounting brackets for all kinds of motors.
http://www.alangrovecomponents.com/
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
