| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | Hi.Im looking at fitting power steering to my 56 265 small block.I was wondering where to fit the pump on the engine.Has anyone fitted one to a 265 and if so how.Cheers | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Just get a factory or after market manual and look at it. 56 came from the factory with power steering with the pump on the rear of the generator. The steering itself was with a ram assist on the tie rod. For an updated version there are p/s units that mount the same as the manual steering box. I prefer the 500 box over the 605 as it gives an easier column hook up. For a non-generator p/s pump mounting there are kits offered or you can make your own using the left front motor mount engine bracket and rear bracing to water pump or exhaust manifold: picture of a 55 265 [img]https://i.postimg.cc/CzdjxBkP/Pete-s-column-and-p-s-pump-004.jpg[/img]
Evan
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Check with Alan Grove to see if they have what you need. They make mounting brackets for all kinds of motors. http://www.alangrovecomponents.com/Mike B  | | |
