6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#1325272 09/07/2019 10:06 PM
Trying to figure out what were the correct emblems for the side of the hood on a 51 6400. The hood only has 2 holes straight across from each other.
ragtopwally #1325297 09/08/2019 1:07 AM
My understanding is that two emblems were used through mid 1952 (when the series number was discontinued).
ragtopwally #1325300 09/08/2019 2:08 AM
A 1951 Chevrolet 6400, should have a "Chevrolet" emblem on each side of the hood, with a small "6400" emblem on each side below the "Chevrolet" emblem. Depending on the Factory it came from, I've seen some 51, and 52 models that did not have the series emblems.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
ragtopwally #1325302 09/08/2019 2:27 AM
ragtopwally #1325698 09/11/2019 1:02 AM
I’ve seen the ones that have a separate 6400 below the Chevrolet and ones that said Chevrolet and 6400 was attached to the top of it. Only holes in this hood are straight across from each other. May have had a replacement hood? Is there a source for new emblems or are we stuck hunting originals?
ragtopwally #1325706 09/11/2019 1:16 AM
M Online: Content
The "CHEVROLET" emblem will be the same as the small trucks and is being reproduced...the "6400" is not reproduced, so you'll need to put a Wanted Ad here on the Bolt to see if someone has a pair laying around.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
ragtopwally #1326281 09/15/2019 11:53 PM
Try searching "Chevrolet 6400 hood side emblems" on Ebay. There are a couple sets on there now.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
