3 members (Otto Skorzeny, baldeagle, carbking), 109 guests, and 2 robots.
Topics128,037
Posts1,055,468
Members48,424
#1325418 09/09/2019 12:07 PM
Hi fellas
I’m finishing up the restoration of the starter for my 235. It is working just fine but I took it apart to clean it and paint it. I bought a new data plate for it but I’m not completely sure on how to properly install the rivets. Just wondering what has worked for others ?
Dan
My rivets were just tap in and they expanded. Came with the data plate.
1950 Chevy 3100
It cost me 2 drill bits but I got the old rivets drilled out. I ordered a set of rivet punches so I don’t flatten the heads when installing them. I believe I wasn’t sure on the installation until I located the original holes and realized they were not drilled all the way thru. I was thinking I needed a bucking bar of some sort.
Restoration of the generator is next. I believe it is working fine just needs cleaning and paint. Should be pretty straight forward
Thanks for the input
Dan
Dan
