5 members (Buckeye998, JoergK., ShopRag, Lightholder's Dad, Rusted Nut), 347 guests, and 3 robots.
Topics128,160
Posts1,057,054
Members48,463
#1325313 09/08/2019 12:18 PM
Just found out the gas tank on my 38 chevy truck has a leak on the top. Does anyone know where I could get a new one? I have searched the parts supplier with no luck. Going now to drain gas out.
1949 3100
Old Blue
Crusing in the Passing Lane
One can clean it well and epoxy a patch of similar tin over it, easy to do since it is in the top, or brake or weld it up.
Ed
Thanks Inc. on the web
1937 GC
Well tank is drained and out of truck. It was patched before. That is where it is leaking. I will have to find a good epoxy to go over the old patches as no luck finding a new tank. Tried tanks inc with no luck. Will call them tomorrow to see if they can make one. Will update when I get it back together. Thanks again for the input.
1949 3100
Old Blue
2 Offline
hi GradyB
a new tank might be nice, but i appreciate and support your desire to fix the one you have.
Warning - always purge your gas tank before attempting to blow yourself up, what i am recommending could be dangerous if not executed properly.
according to JBWeld documentation,
if applied on clean metal without oil or gas the fully cured epoxy is rated for full gasoline contact, including modern fuel and oils.
however, even a trace of motor oil will keep it from curing proper, i have experienced this phenomena first hand, i would expect most components of gasoline would have the same undesired affect to the curing process. i suggest you bake out all the oils and gas at the local spot before applying the epoxy,
using a propane torch would likely be sufficient, scrub the surface clean after you cook it good.
heat should also allow you to bake off all the old epoxy without so much effort, it will turn to ash before the steel deforms.
but...
if it was me, since it's off the truck, i would go for the acetylene torch and braze a new steel patch in place.
I love JBweld, but if i can put metal on it that's the way to go.
-s
