0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#1325336 09/08/2019 5:52 PM
I have a 1960 Chevy 1/2 ton with a 283 and four speed. I just replaced the master cylinder and the hydraulic clutch slave cylinder hydraulic line. I'm not getting any brake fluid to the slave cylinder. I have brake pedal but no clutch. The clutch pedal goes to the floor and stays. Any suggestions?
Sir Searchalot
Sir Searchalot
Get a 1960 manual and install per that. It is not real technical. Adjust per manual, including pedal travel, plumbing, return spring, push rod adjustment. You will find the problem.
You say you are not getting any brake fluid to the slave. Check reservoir fill. Check under dash push rod and slave push rod adjustment per manual. I assume you bled the slave?...and see no fluid?
Crusing in the Passing Lane
Make sure the clutch master goes to the slave, brake master goes to brakes!
Ed
Sir Searchalot
Sir Searchalot
I thought that too but he said he had brake pedal.
The master to slave cylinder is just a straight column of fluid with no residual pressure valve incorporated into the flare fitting seat like the brake side. When the pedal goes down so does the fluid and when the pedal comes back up so does the fluid. This makes the pump up and bleed method impossible. We have had our best luck reverse bleeding; pushing pressurized fluid into the bleeder valve till master cylinder overflows. Another method (gravity bleed) is to top off mc and barely crack open the bleeder valve and let set overnight. If there is several drops of fluid on the floor in the morning shut bleeder and you should have a working clutch. I could use a 60-62 bell housing with the passenger side clutch release arm so if you have an extra let me know.
Evan
Sir Searchalot
Sir Searchalot
The slave has a bleeder valve. The manual says bleed there. Push on clutch pedal, open valve, close valve before reaching bottom. Then let pedal up. Easy.
I will try cracking open the bleeder valve and letting it sit. The info about the fluid movement is certainly helpful. Thanks to everyone. I'll post my results.
Thanks to everyone for the advice. Bartamos and coilover nailed the solution.
