| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 46 | Trying to figure out what were the correct emblems for the side of the hood on a 51 6400. The hood only has 2 holes straight across from each other. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My understanding is that two emblems were used through mid 1952 (when the series number was discontinued). | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | A 1951 Chevrolet 6400, should have a "Chevrolet" emblem on each side of the hood, with a small "6400" emblem on each side below the "Chevrolet" emblem. Depending on the Factory it came from, I've seen some 51, and 52 models that did not have the series emblems. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 46 | I’ve seen the ones that have a separate 6400 below the Chevrolet and ones that said Chevrolet and 6400 was attached to the top of it. Only holes in this hood are straight across from each other. May have had a replacement hood? Is there a source for new emblems or are we stuck hunting originals? | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | The "CHEVROLET" emblem will be the same as the small trucks and is being reproduced...the "6400" is not reproduced, so you'll need to put a Wanted Ad here on the Bolt to see if someone has a pair laying around. Mike B  | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Try searching "Chevrolet 6400 hood side emblems" on Ebay. There are a couple sets on there now.
