1 members (DaveV),
109
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13252 03/31/2005 2:32 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Can any help I can find out the block # 3837004 turns out to be 1955-1957 but witch year? The other # next too the distributor Is F56X.
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#13253 03/31/2005 3:27 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | June 5th 1956, 235ci - prolly originally put in a 56, but maybe a 57 if engine prod was boomin at the time, cuz by that timea year they were starting the switchover to the new years model - won't make any difference for parts requirements or tuneup specs tho
Bill | | |
#13254 03/31/2005 7:58 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | The F56X looks like the engine serial number suffix in the same format as for '54 and '55, so it would not be a date code (similar to casting date codes) as translated by red58. I think the engine serial number format changed for '57 to include the date code (with the month as 1 or 2 digits, and the day as 2 digits, and no year). If I'm right, F=Flint engine plant, 56=model year, X=type code=235 from 3100 series. So your engine is a '56. Was there a sequence number stamped before the F56X on the pad by the distributor?
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#13255 04/01/2005 3:04 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Yes the # stamped before F56X is 0365785 thank you for the help. 0365785 F56X
