| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Recently put an engine together and fired it up and the first sound I heard was a horrible scraping noise coming off the front of the motor. A thousand thoughts rushed into my head as to what the cause was. All along thinking of all the money in parts and machining that had gone into the project. It was hard for me to shut the engine down because I had to break in the cam but didn't want the engine to eat itself either. Quick work with a stethescope revealed the issue. Noise out of the balancer. Problem is with these balancers for stovebolt 6s are the pulley is on the inside and there is no way to visually see if the balancer is fit for duty that I could tell.
Can anyone offer any encouraging words on how to purchase a used balancer and any checks to see if it is good to go or not? How can one tell short of pressing it on the crankshaft and see?
Steve
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Why not just build up a balancer using new parts? It's pretty simple, and there are at least two new stock balancers that can be fitted to 216/235/261 engines with a minimal amount of machining. Jerry
