| | | Forums66 Topics128,090 Posts1,056,015 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2019 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 13 | Can someone tell me if it is realistic to try and put a 3600 49 frame under a 53 3600 cab. I’m looking at purchasing the 49 frame with everything but the cab and engine/trans in great shape. My current project is a 53 3600 that needs a bit of love (springs, kingpins, brakes etc etc etc). Is this a viable option to swap out? Maybe just buy for extra parts? | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Someone with more knowledge will need to chime in here. However, the little I know is that the cab mounting changed sometime in the late '40's from a 3 point mount to the 4 point mount that ran through the end of the advance design series. I just don't remember when that changeover happened. All that to say, that if your cab mounts are the same, you should be golden
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | Even if the 49 frame has the three point mount, it could be used by drilling for the pair of cab shackles on the frame. If they're not there, myself or one of the other guys here could help you with dimensions for the holes.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2019 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 13 | Thanks for the info, sounds like this might be a good option for me, anyone know about the parking brake linkage? That’s the only thing besides cab mount that might be a challenge if they are intact different | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | '49 frame is virtually the same as the '53. Cabs mount the same (rear shackles).
