5 members (walter74, Ponchogl, moparguy, 55shaker, 1 invisible), 147 guests, and 7 robots.
Topics128,089
Posts1,056,138
Members48,435
#1324918 09/05/2019 6:56 AM
Hi All,
Can someone share what the measurements are for 216 and 235 engine? There is local debate amongst car guys in my area on which of the motors is longer than the other. The question came up as I was discussing swapping the 216 out of my 39 pickup for a full pressure 1954 235. The debate is over clearance issues. They are insisting that the 235 is longer than the 216. Can someone provide the actual measurements?
Thanks!
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
They are the same if you use the 1954 engine, later models (55-up) might throw the fan a little forward depending if the later water pump would be used.
Check out this article:
https://www.stovebolt.com/techtips/engine_swap_216.htm
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Sergio,
Just in case you get odd responses/arguments from your friends, regarding the high-pressure 1954 235/261 (and some early 1955 235/261s) that sstock correctly refers-to as high-pressure engines: your friends might not know that 1937-1953 low-pressure 235s were also the same length as the low-pressure 216s.
Just a side note: The GMC I-6s are longer which may cause they’re confusion.🛠
There can in some cases be an issue with oil pan.
Chevrolet did not start using a rear crank seal until 1940.
At that time the oil pan was redesigned and extends further back.
In some conversions the pan can interfere with the crossmember and some modification of the pan or crossmember will be needed.
My Blog
