3 members (MRMEROTH11, WICruiser, wilbur53), 111 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#1324876 09/04/2019 11:49 PM
Can someone tell me if it is realistic to try and put a 3600 49 frame under a 53 3600 cab. I’m looking at purchasing the 49 frame with everything but the cab and engine/trans in great shape. My current project is a 53 3600 that needs a bit of love (springs, kingpins, brakes etc etc etc). Is this a viable option to swap out? Maybe just buy for extra parts?
Someone with more knowledge will need to chime in here. However, the little I know is that the cab mounting changed sometime in the late '40's from a 3 point mount to the 4 point mount that ran through the end of the advance design series. I just don't remember when that changeover happened. All that to say, that if your cab mounts are the same, you should be golden
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
Even if the 49 frame has the three point mount, it could be used by drilling for the pair of cab shackles on the frame. If they're not there, myself or one of the other guys here could help you with dimensions for the holes.
Thanks for the info, sounds like this might be a good option for me, anyone know about the parking brake linkage? That’s the only thing besides cab mount that might be a challenge if they are intact different
'49 frame is virtually the same as the '53. Cabs mount the same (rear shackles).
