2 members (PAUL Berardi, 78buckshot), 175 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1324212 08/30/2019 8:26 PM
Would a Carter YF 4371S be OK to use on a 235 CID? I know that they were originally made for 250s and 292s. Just inquiring for a friend. I'm not sure.
Thanks.
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
That one will probably run a little lean on the smaller engine- - - -not enough venturi velocity to mix enough gasoline with the air passing through. You might richen up the main jet a little, but it would be a better choice to stick with the right carb for the engine.
I agree with using the correct carb on these engines. I think he's looking to use what he has at this point to get the truck running. Thanks Jerry.
I did something similar when I was back in high school. I had a 47 Ford coupe with a flathead V8, bored 80 thousandths oversize. That turned a 239 cubic inch engine into a 252. I installed a 2-barrel carb for a 55 Ford 272, and got a horrible flat spot on acceleration. Even with drilled-out main jets and lousy gas mileage, the bog just off idle just wouldn't go away. I had to nurse the RPM up a little at a time to get up to the point I could nail the throttle. It ran pretty good once the engine was wound up, but getting there was a challenge!
Carburetion specialist
C Online: Content
While I completely agree with Jerry about lower air velocity on O.E. carburetors, this one is not O.E.
Carburetion 101 - the three major methods of helping atomize fuel are: (A) heat, (B) higher air velocity, and (C) throw more fuel at the engine.
Carter released the 4371s for replacement on standard transmission 230, 250, and 292 engines. These "one size fit all carbs" are generally calibrated much richer than O.E. carbs (see "C" above).
It should work, albeit not as well as one designed specifically for the 235. And fuel mileage will probably not be good.
Jon.
The Carburetor Shop
California gas prices are horrible. He may have to bite the bullet on poor fuel mileage with this carb for a while.
