2 members (68ironhead, Gdads51), 59 guests, and 1 robot.
Topics128,049
Posts1,055,691
#1324391 09/01/2019 7:39 PM
1 Offline
Hello everyone! So I finally gave up on my Rochester B carb and ordered a replacement equivalent. The main question I have is with all the gaskets I have, I'm not sure what is supposed to have a gasket and what is not? My main question is in between the intake and the carb insulator, is there supposed to be a gasket? I know there's a gasket between the carb insulator and the carb itself. If I put one between the intake and carb insulator, as well as the insulator and carb, there wasn't much thread for the nuts to thread on to, which leads me to believe there isn't supposed to be one between the intake and carb insulator. The other reason why I'm questioning it, is because when I put the carb insulator on the intake, it's not 100% flush and I'm worried there will be an air leak. Thank you in advance for your help!
Put a gasket between the carburetor and the insulator, orientating/aligning the "cut-out" in the gasket to a hole in the base of the carburetor.
I put a gasket between the insulator and the intake manifold.
You can probably unscrew the studs out of the intake manifold a couple of threads, as long as you reinstall them with red Loc Tite. That will probably give you just enough extra stud length to use a gasket on both sides of the insulator. It might not be absolutely necessary, but it probably won't hurt, either. Just be sure not to block any vacuum passages with the gasket(s).
If you remove the studs, you can also draw-file the top of the manifold or use a disc sander on it to be sure it's flat before re-installing the studs or putting longer ones in.
0
0 Offline
Just curious....What did you replace the Rochester 'B' with ?.....On a previous thread, I thought to have issues with my Rochester 'B' - then after receiving much good advise, to check vacuum, timing, ect, I'm back to the carburetor.......I am very apprehensive to purchase another Rochester 'B' rebuilt, used, even a very expensive NOS....Reading these threads its clear that the Rochester 'B' is problematic and does not have such a good reputation......Now as a temporary solution, I'm thinking to buy one of those Chinese reproduction 'B' for about $70.00.....However this Chinese carb would be temporary till I found a suitable period era carb.....So my question is: What would be a good reliable alternative for the Rochester 'B'?
"The ABC's of carburetion- - - -Always Buy Carter!"
Carburetion specialist
$70. for the clone; $4000. for the automatic underhood halon fire estinguisher.
Good luck.
Jon.
The Carburetor Shop
0
0 Offline
If I don't start getting some respect from that truck the fire might be the solution!....I am no fan of anything Chinese....even food.....my key word was "temporary"....I have yet to drive this heap,(recent acquisition), not even the 500 feet to the end of my driveway! Was just wondering if anyone had any success with those Chinese carbs....Gotta beat the tariff increase! Well Jerry gave me 1/2 of the answer....What type/model Carter should I be looking for, and would it be a 'plug & play' will the factory air cleaner fit?
Carter YF carburetors produced for use on Chevrolet
756s � 216 engine aftermarket 1937~1952
787s � 216 engine aftermarket 1937~1952
788s � 235 engine aftermarket 1950~1952
789s � 235 engine aftermarket 1950~1952
890s � 235 engine aftermarket manual choke (number assigned, no production)
891s � 235 engine aftermarket auto choke (number assigned, no production)
964s � 216 engine aftermarket manual choke 1937~1952
965s � 216 engine aftermarket auto choke 1937~1952
966s � 235 engine aftermarket auto choke 1950~1952
967s � 235 engine aftermarket manual choke 1950~1952
2008s � 216 engine aftermarket 1937~1952
2046s � 206 engine aftermarket 1932~1936
2100s � 235 engine aftermarket manual choke 1953~1956
2101s � 235 engine aftermarket auto choke 1953~1956
2104s � 261 engine aftermarket (number assigned, no production)
3055s � aftermarket (number assigned, no production)
3211s � 235 engine aftermarket 1957~1962
3379s � 153 engine original equipment manual trans 1962~1966
3402s � 153 engine original equipment auto trans 1962~1966
3711s � 194 engine aftermarket 1962
3760s � 230 engine (number assigned, no production)
3770s � 230 engine (taxi) original equipment auto transmission 1964~1965
3771s � 230 engine (taxi) original equipment manual trans 1964~1965
3772s � 194 engine auto transmission (number assigned, no production) 1964
3773s � 194 engine manual trans (number assigned, no production) 1964
3821s � 194 engine (van) original equipment 1964
3946s � 194 engine aftermarket 1964~1965
3946s � 230 engine aftermarket 1964~1965
3975s � 230 engine (van) original equipment manual trans 1965
3976s � 230 engine (van) original equipment auto trans 1965
4043s � 194 engine (van) original equipment manual trans 1966
4043s � 230 engine (van) original equipment manual trans 1966
4044s � 194 engine (van) original equipment auto trans 1966
4044s � 230 engine (van) original equipment auto trans 1966
4048s � 230 engine (van) aftermarket experimental 1963~1966
4072s � 194 engine original equipment auto trans CALIF smog 1966
4072s � 230 engine original equipment auto trans CALIF smog 1966
4073s � 194 engine original equipment manual trans CALIF smog 1966
4073s � 230 engine original equipment manual trans CALIF smog 1966
4080s � 194 engine original equipment (pass) auto trans CALIF smog 1966
4080s � 230 engine original equipment (pass) auto trans CALIF smog 1966
4080s � 250 engine original equipment (pass) auto trans CALIF smog 1966
4085s � 230 engine original equipment (truck) manual trans CALIF smog 1966
4085s � 250 engine original equipment (truck) manual trans CALIF smog 1966
4086s � 230 engine original equipment (truck) auto trans CALIF smog 1966
4086s � 250 engine original equipment (truck) auto trans CALIF smog 1966
4145s � 194 engine original equipment (truck) manual trans 1965~1966
4145s � 230 engine original equipment (truck) manual trans 1965~1966
4202s � 250 engine (taxi) original equipment auto trans 1966
4203s � 250 engine (taxi) original equipment manual trans 1966
4278s � (export to India)
4339s � 194 engine aftermarket 1963~1967
4339s � 230 engine aftermarket 1963~1967
4339s � 250 engine aftermarket 1963~1967
4367s � 230 engine original equipment manual trans CALIF smog 1967
4367s � 250 engine original equipment manual trans CALIF smog 1967
4368s � 194 engine original equipment auto trans CALIF smog 1967
4368s � 230 engine original equipment auto trans CALIF smog 1967
4368s � 250 engine original equipment auto trans CALIF smog 1967
4369s � 230 engine original equipment (truck) manual trans CALIF smog 1967
4369s � 250 engine original equipment (truck) manual trans CALIF smog 1967
4370s � 230 engine original equipment (truck) auto trans CALIF smog 1967
4370s � 250 engine original equipment (truck) auto trans CALIF smog 1967
4371s � 230 engine original equipment (truck) manual trans CALIF smog 1967
4371s � 250 engine original equipment (truck) manual trans CALIF smog 1967
4371s � 292 engine original equipment (truck) manual trans CALIF smog 1967
4372s � 250 engine original equipment (truck) auto trans CALIF smog 1967
4373s � 153 engine aftermarket manual trans 1963~1967
4374s � 153 engine aftermarket auto trans 1963~1967
4375s � 230 engine original equipment (truck) manual trans 1967
4375s � 250 engine original equipment (truck) manual trans 1967
4376s � 230 engine original equipment (truck) auto trans 1967
4376s � 250 engine original equipment (truck) auto trans 1967
4377s � 250 engine original equipment (taxi) manual trans CALIF smog 1967
4378s � 250 engine original equipment (taxi) auto trans CALIF smog 1967
4387s � 194 engine original equipment (truck) manual trans CALIF smog 1967
4480s � 230 engine aftermarket (all Federal) 1963~1967
4480s � 250 engine aftermarket (all Federal) 1963~1967
4492s � 194 engine aftermarket 1962
6213s � number assigned no productio
1950 Chevy 3100
Aside from QC problems (the people assembling them in Guangdon will not be driving your car) they are not accurately spec'd to your engine, but (IIRC) an average of the range of L6 engine types (OHV and SV) and displacements they anticipate as buyers. This includes 216, 235, 261, GMC, Chrysler Spitfire, Ply-Do, Ford 223, Pontiac 239, etc.
There really is no universal replacement carburetor.
0
0 Offline
OK...so for my application the Rochester B & the Carter YF would be OEM carburetors, specific to the vehicle? - That is quite a list above.....
