| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | As some of you know i have a 1951 chevy 3100 with a 1954 235 in it with a extreme amount of issues after i had it rebuilt. Currently i have 2 outstanding problems. For starters i have a brand new (rebuild) carburetor (roch model B) and when it is idling fuel almost pours out of the throttle shaft as if its supposed to. my guess is the needle seat is damaged or not seating, or perhaps the fuel pump is making too much pressure. second. i think its relating to the carburetor issue, but when its running it sounds like 2 cylinders arent firing at all. it almost sounds like a rotary engine. i havent ran it for more than a minute so hopefully no damage has resulted. timing is correct, it has brand new champion plugs gapped at .035, correct oil bath air filter is in place with oil in it, havent checked vacuum in a little while, and from my knowledge of smells, its running extremely rich, im not sure rich is the right word. should i start on the carb or check elsewhere? has anyone else had a similar issue? any help is appreciated, i need to know where to start.
Owner of the most temperamental 1951 3100 in existence
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I’d try a different carb that was running fine on another engine first. | | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | the original carb i rebuilt myself and it had the exact same issue, it would flood fuel out of the throttle arm. could it be a fuel pump?
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | What's the fuel pressure? "Test- - - -don't guess!" It should be somewhat less than 5 PSI. Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | If you have a Chinese repop fuel pump it's likely that the fuel pressure is high. One I had would run OK but when I shut it off and let it sit for a few minutes it would flood. Put out 7 PSI.
When you overhauled the carb, did you check the float drop? I found one that had so much drop that the needle would hang up because the float would try to push it sideways. It would flood till you banged on the carb with a wrench. After a while with heavy load it would do it again. Does the float float? Did you check it for leaks by shaking it by your ear to listen for sloshing? Is it plastic? I've seen alcohol permeate them till they sink. Cork too.
As for misfiring on two cylinders, I'd check for gas fouled plugs (Black). 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | i pulled the plugs and its definately running rich, which could be as a result of the fuel issue, or rather it probably is. all i know is the carb was "professionally" rebuilt. everything was reseated, and so on, like new essentially. when i go to put a fuel filter in the line ill run a pressure test. for now ill tear down the carb and make sure its 100%. i still have the old carb, which would do the identical thing. perhaps then would it be too much fuel pressure? the old carb i rebuilt myself and i made sure everything was 100% spec before putting it on the engine. ill give some more testing and see what i come up with.
| | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | this thing is the biggest money pit ever. im pretty positive my fuel pump pressure is way too high. cant get a break with these old works of art can ya?
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Did you test the fuel pressure? "Pretty positive" is nearly synonymous with "I have no idea whatsoever", without putting a fuel pressure gauge on it. Your statement of "100% spec" needs to include testing the pressure.
| | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | Update: i found the issue. the people who restored the carb used a metal needle in it. also the flow in port was all gunked up with what looked like a finger nail and hair. i replaced a few parts and presto! no leak whatsoever and it runs 100% better. finally works like it should!
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | What's wrong with a metal needle valve? GM installed millions of them, as did Carter, Zenith, MOPAR, Ford and a bunch of other manufacturers. Jerry
| | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | nothing was wrong with it but i decided to use a rubber tip to avoid any possible issue. thats all
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Good luck with that decision.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The rubber tipped ones don't work with fingernails and hair either.  Sounds like you got it figured out.
| | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | As London as its Viton and not.Butyl rubber
Current project; 1961 C20, 235 I6
| | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | As long as it is viton is what I meant
