0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 14 New Guy | | New Guy Joined: Apr 2017 Posts: 14 | Gentlemen, My big feet simply do not fit into the space between the shifter and gas pedal to start my 1941 GMC CC303 (running original four speed with 6 volt ring gear) with any semblance of consistency. Do any of you fine fellows KNOW which solenoid type starter will fit this truck either by part number OR original application?
1941GMC CC303 converted to tilt bed car carrier 1941 IH KB7 crane 1959 Hillman Husky Motown SB427 @581HP 1965 Sunbeam Tiger 2006 Ford F-150 Super Crew NASCAR edition
Peter A. Schmitz
41' 1-1/2 Ton GMC flatbed '41 1-1/2 Ton IH crane/truck 1986 F700 Tall Box Truck '65 Sunbeam Tiger '59 Hillman Husky '94 Mercedes S500 coupe '99 Suburban 4WD Can be reached for personal business at 714-290-2470
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Peter, You would most likely need a 6v positive ground solenoid starter set-up for your 1941 GMC. What size/year engine? Someone here might know what to use. However, most likely someone on oldGMCtrucks.com discussion board would surely be able to provide helpful/correct suggestions. | | | | | Joined: Apr 2017 Posts: 14 New Guy | | New Guy Joined: Apr 2017 Posts: 14 | I am already running a 12v negative ground. Starter rotates correctly regardless of polarity applied. Saw that he, and sure enough truck started and ran fine. I have read other threads that almost say which one but they seem to assume everyone knows which part number or application to use in place of stomp type.
Peter A. Schmitz
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | You need a Chevy standard shift passenger car starter from about 1950-54, assuming you're still running a 6V electric system. Positive or negative ground doesn't matter- - - -the starter will work OK either way. Jerry
