1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | How do I remove the shaft from the tube on my 51 3100. Thank you in advance, Gerry | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 |
Mike
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't understand. The driveshaft should not be in a tube on a 51 3804. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | OP asked specifically about a "51 3100 shaft" (even though his Call Name is "51 3804").
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am sorry I missed that. So have you read the manual on this operation? | | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | Yes I have read the manual and unfortunatly I don't have the bearing puller. Thank you, Gerry | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have only done this when doing a 3.55 Ring & Pinion conversion. That necessitates a full disassembly of the torque-tube rear-end assembly. Here is a Tech Tip on that operation.Step 12 onwards? If there is a simpler procedure, let's hope someone posts it? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | You may be able to rent/borrow the bearing puller from your local FLAPS.
Ed
| | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | Thanks Tim I will try that over the weekend. I was going to try something like that but was worried that I would ruin something! Thanks again, Gerry | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Gerry,
I was also a little scared on my first disassembly/assembly. I had the benefit of a mechanic-friend being with me. However, he had never dealt with an enclosed driveshaft; and, I think he was a little amazed. We got it done - changing from 3.90 to 3.55 R&P.
Go slowly, ask questions here, post pictures (if necessary, and if you can). Good luck. | | |
