2 members (Hotrod Lincoln, homer52), 93 guests, and 0 robots.
Topics128,049
Posts1,055,638
#1323597 08/26/2019 5:43 PM
How do I remove the shaft from the tube on my 51 3100. Thank you in advance, Gerry
51 3804 #1323697 08/27/2019 12:35 PM
Mike
51 3804 #1323703 08/27/2019 1:33 PM
I don't understand. The driveshaft should not be in a tube on a 51 3804.
1951 1 Ton Completed
51 3804 #1323796 08/28/2019 12:56 AM
OP asked specifically about a "51 3100 shaft" (even though his Call Name is "51 3804").
51 3804 #1323800 08/28/2019 1:11 AM
I am sorry I missed that. So have you read the manual on this operation?
51 3804 #1323827 08/28/2019 11:26 AM
Yes I have read the manual and unfortunatly I don't have the bearing puller. Thank you, Gerry
51 3804 #1323829 08/28/2019 11:40 AM
I have only done this when doing a 3.55 Ring & Pinion conversion.
That necessitates a full disassembly of the torque-tube rear-end assembly.
Here is a Tech Tip on that operation.
Step 12 onwards?
If there is a simpler procedure, let's hope someone posts it?
51 3804 #1323847 08/28/2019 2:31 PM
You may be able to rent/borrow the bearing puller from your local FLAPS.
Ed
51 3804 #1323972 08/29/2019 11:57 AM
Thanks Tim I will try that over the weekend. I was going to try something like that but was worried that I would ruin something! Thanks again, Gerry
51 3804 #1323982 08/29/2019 12:38 PM
Gerry,
I was also a little scared on my first disassembly/assembly. I had the benefit of a mechanic-friend being with me. However, he had never dealt with an enclosed driveshaft; and, I think he was a little amazed. We got it done - changing from 3.90 to 3.55 R&P.
Go slowly, ask questions here, post pictures (if necessary, and if you can).
Good luck.
