4 members (37 GC, IHPWR, Hotrod Lincoln, NJC), 141 guests, and 2 robots.
Topics128,141
Posts1,056,780
Members48,454
#1323329 08/24/2019 11:55 PM
Probably a dumb question, but am planning on removing my hood tomorrow. I'm thinking it doesn't weight but maybe thirty pounds, but don't want to be surprised. Anyone know the weight of an AD, 3100 hood?
'52 Chevy 1/2 ton running original gear
daveboy #1323336 08/25/2019 12:55 AM
I'll bet more than 30 lbs.
Nonetheless, it is at least a two person job - three people would be the best.
If you first have all the hinge bolts a little loosened-a-little by yourself, the other two people would be needed for about 5-10 minutes (to carefully walk the hood forward, off/over the front of the "body").
Make sure you have enough space at the front of the truck, so that the hood can be removed forward.
Let's see what other members post.
Tim is right...the weight is not the issue. One person can handle it but is a stretch and very awkward. If it is off the truck one can move it around. Trying to remove it and clear the width of the fenders, you would need strong orangutan arms at least. Best get some help...
daveboy #1323360 08/25/2019 5:05 AM
A refrigerator is too heavy for one person to carry. The empty box is not heavy at all, but too awkward to handle easily by yourself.
Same for an AD hood. I have done it by myself, but I am stupid.
Two people, grasping it from the sides makes it a breeze.
daveboy #1323426 08/25/2019 4:49 PM
I seem to always have to do this stuff myself. I've come up with the proper size prop to put in front of the hood to hold it up. A piece of 1" x 2" wood. I'll remove the springs first and fold them down next to the fender. I then place a towel or blanket on the cowl so that the paint won't get scratched. Then I'll remove the hinges one side at a time and let the hood corners rest on the cowl. Once free, I'll go to the front, remove the wood while supporting the hood, put one hand at the nose and one in the middle seam somewhere and lift. I use the reverse procedure to install.
daveboy #1323519 08/26/2019 1:40 AM
Thanks for the info. I got it off today. Had two helpers so that I could just remove the bolts while they took the weight.
daveboy #1323556 08/26/2019 12:17 PM
thumbs_up
Better safe than sorry . . .
