6 members (Hugh63c10, moparguy, 32Fordpuchoptop, Hanks custodian, ShopRag, Ponchogl), 135 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
#132302 12/08/2004 5:06 AM
Junior Member
Junior Member
Hello, I am in the process of installing a mustang II ifs. I was wondering if I need to put the cab on the frame to do this. I have a 41 Chevy truck. I have been told you should, to make sure it's squared. The install instructions don't mention this. Any help would be appreciated. Thanks
#132303 12/08/2004 12:28 PM
Did you mark the frame for axle centerline before you tore it down? I didn't (just measured and screwed up) and wound up cutting out the IFS and moving it back 2". Not fun.
If you haven't, I'd strongly suggest putting the cab and fenders in place and marking (drilled hole so you can't grind it off) where you want the centerline to be.
http://www.chuckthetruck.homestead.com/page16.html
#132304 12/08/2004 6:07 PM
Its not that you need the cab in place to make sure you get the suspension square. What you care about is that the suspension be square with the frame. You'll square the cab to the frame later.
The reason to put the cab and fenders on now would be to make sure the wheels end up sitting in the wheel well the way you want.
I'd suggest mocking up the truck, with the intended wheels and tires, sitting under the fenders. Make sure they are set at the correct track width, and then adjust the body up and down and the wheels fore and aft to get the look you want.
Verify that you'll still be able to turn and that there are no interference problems, and if all is well, mark the axle centerline and measure the height (frame above floor) so you'll be able to put the crossmember in the right place to get that look.
Its a lot more work than a couple paragraphs!
#132305 12/18/2004 9:07 PM
Good advice from chuckthetruck.Mark your center line on the frame to make sure you wheels remain the same front to rear.I had good instructions when I put mine in.The proper measurments etc..On mine I measured back from the front of the frame,then did an X measurement to make sure it was square. Good luck
