11 members (55shaker, Cletus1950, RoadsScholar, Otto Skorzeny, carbking, fonz8261, Greg_H, Hotrod Lincoln, Peggy M, 2 invisible),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | My C-60 with a SM420 transmission has a PTO to run the dump bed. The PTO is an A series (replaced by 100 series) Chelsea made by Dana (Spicer)
Does anyone know where I can find a parts book and or rebuild kit for a 1960’s Chelsea PTO made by Dana? I have searched to no avail. | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | There's not much to rebuild... The seals will have a number stamped on it. Roller/ball bearings will have numbers on them...if they are bushings and they are worn you can have new ones made at a machine shop You can make a gasket the same thickness as the original one (gasket acts as a shim to put the gear in a good mating location with the drive gear). If the shaft is worn, take it to a machine shop and have a new one made. If the gear is worn, buy another used PTO unit with a better gear. Just make sure the replacement PTO came off of a SM-420 as the driven gears are custom to the make/model of the trans they are bolted to. Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Useful document, shows the adapter gear for my Spicer 5553a trans., will not hold still enough to print though.
Ed
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks for sharing the document. If your old PTO proves to be unrebuildable, I have a nearly new Chelsea that was on a SM420 that I would let go. | | |
