0 members (),
364
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 93 Shop Shark | | Shop Shark Joined: Apr 2017 Posts: 93 | I am looking for a gasket for my 1.5 ton Chevy (single speed rear end) rear differential carrier. I haven't had much luck online for the 1.5 ton, but found 1/2 thru 1 ton gaskets. Are they the same? | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I'm almost certain they're not the same. You could go to your FLAPS and buy some medium thickness gasket paper and make on. It's not hard. Use a ball peen hammer and tap tap tap around all the edges and the bolt holes. When you get the big hole taped out then you can slip it over the ring gear etc. and tap out the outside dimension or use scissors. While you're at it make one for the rear cover. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I'm almost certain they're not the same. You could go to your FLAPS and buy some medium thickness gasket paper and make one. It's not hard. Use a ball peen hammer and tap tap tap around all the edges and the bolt holes. When you get the big hole taped out then you can slip it over the ring gear etc. and tap out the outside dimension or use scissors. While you're at it make one for the rear cover. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Differential carrier gasket thickness is likely figured into the assembly and alignment of the assembled unit. Therefore best to find original gasket or make one same thickness and not use something different. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Large Manila folders come in blond(thin)and green(thick), make good gasket material.
Ed
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Grigg, educate me. It seems to me that the gear assembly bolts into the housing as a unit so regardless of gasket thickness the gear alignment would remain the same. The axle alignment might be off a few thousanths but does that matter over the length of the axle of several feet? The housing probably flexes more than that. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I know anecdotal evidence is suspect, however, I mounted the differential carrier on my '50 Chevy COE without a gasket and 2300 miles later no problems at all. I could not find a gasket, so I used Permatex "Right Stuff" which is a wonderful product, designed for OEM placement of diesel oil pans without a gasket. It is more adhesive than Permatex #2 but does not allow seepage or creep of oil like you see with #2 or RTV.
Based on my experience of one, I tend to agree with 1ton tommy in that axle alignment might be off a few thousandths but it would not matter much.
Thoughts?
Kent | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It may be a slight enough difference to not matter much, I agree.
I like to do things right to the best of my ability/knowledge. I also believe in providing sound advice. Thus the recommendation to use the original thickness gasket and the reason why it might matter. Then whoever chooses can follow it or not and base that decision on a sound understanding of the situation.
When you don't understand all the factors involved and make "judgement calls" the results aren't always pleasing. Or better to know when you're cutting corners than be surprised when it didn't work out.
PS To add to the gasket thickness discussion (without having them to measure) I suspect the differential cover gasket is 1/16" thick, and the carrier gasket 1/64 or 1/32"; same shape and same bolt pattern. If gasket thickness didn't matter why didn't GM only offer one thickness gasket, less trouble and expense to make and stock one instead of two? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I put my 1 Ton differential together with the correct gasket. I found that the splines left very little room for error and were a bit tricky to get started into the assembly. I think the spines are a fairly precise fit. | | |
