| | | Forums66 Topics128,162 Posts1,056,932 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | I'm making plans in advance on the reassembly of the inner fenders, fenders, to radiator support, grille , etc. and need some advice from those who've done it. I read, copied & saved 52 Carl's write up on " Front Clip alignment procedure " . It occurred to me that even though I took it all apart, I have no idea the " right way" to reassemble the front clip prior to mounting it (loosely) to the cab. Since all the pieces are going to be painted this needs to be done correctly. I searched the site and did not find anything so I'm asking for help. If the "process" has been addressed in another post, please point me in the right direction. Thanks everyone.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | 1) Install the hood on the cowl, springs and all. It's easier to do it first before the fenders are in the way. Leave hood in the up position. 2) Mount the radiator support frame loosely onto the front crossmember. Start out with about 1/4" rubber shims under the feet. 3) Bolt the inner and outer fenders together OFF THE TRUCK. 4) Install the inner and outer fenders onto the truck AS A UNIT. It will go lots easier. 5) Install the large curved fender brackets between the radiator support and the outer edge of the fenders 6) Install the lower front splash shield. Connect the rods from it to the radiator support. 7) Install the grille. 8) Install the hood latch panel between the grille and the radiator support. 9) Install the radiator. 10) Install front bumper. 11) Install the front bumper filler panel.
1951 Chevy Panel Truck
| | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | miraclepieco, thank you. I had read several suggestions on assembling the "front clip" and then with three or four people, putting it on the truck as a unit. then do the adjustments. Thanks for your input.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Great stuff there miraclepieco! Likely how the factory did it. Now to find where I wrote down what all hardware went to what...I'm going to replace all the hardware, cause, well, its 70 years old. | | |
