2 members (1955 1 Series, Hotrod Lincoln), 148 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#1322099 08/16/2019 5:30 PM
Im at a point where I need to buy some body filler for my project. In the past, I have only used Bondo brand, but I noticed that most of you prefer others. Since I've never been real good at application or finishing of it anyway, I need to give myself all the help that I can. Please tell my which ones are your favorites, based on ease of use and quality. I did notice that the RAGE brand has several different types, i.e. gold, premium, etc etc. They all read similar, so how do I figure out which will work best for me. All help appreciated. I'd like to add, that the help I get from this list is absolutely great. Having this kind of help is a wonderful thing.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
I had a body shop owner recommend All Metal to me. I haven't gotten to the point of filler yet, though.
Moderator, Electrical Bay
Things have changed now, Mike. Bondo Lightweight is still very popular and some of the Rage products are also. I think the contest would be between Bondo Lightweight and Rage Gold Premium, but I'll let somebody else decide the winner. I will tell you hardeners have changed. I don't know what they did to them, but it wasn't a good change and I started noticing it about 3 years ago. Today in hot weather it sets really fast and in cold weather it can take a day or more to set. Fiberglass hardener now works the same way and it does take some getting used to. Last winter I did some fiberglass work which took 3 days before it could be sanded and it was mixed right by the book. Good luck!
~ Jon
Rage Extreme
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Most fillers good, I like to add evercoat plastic honey to filler so I can adjust consistency .This also helps to minimize pinholes,hope this helps.
He's messing with your head. He likely wants you to make a mess of it so he you end up taking it to him to fix. All Metal is an aluminum filler and not a product you want to use, unless you are an expert technician and know exactly why you are using this particular product.
Get a good gallon of Evercoat Rage Gold or similar and have a much easier time with it than you ever would with All Metal.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Well he won't be getting it to fix if I try that, because he closed his shop. As I mentioned, I haven't gotten to filler yet, so will research more before starting. I do have some experience using filler, but it was about 50 years ago.
