| | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Im at a point where I need to buy some body filler for my project. In the past, I have only used Bondo brand, but I noticed that most of you prefer others. Since I've never been real good at application or finishing of it anyway, I need to give myself all the help that I can. Please tell my which ones are your favorites, based on ease of use and quality. I did notice that the RAGE brand has several different types, i.e. gold, premium, etc etc. They all read similar, so how do I figure out which will work best for me. All help appreciated. I'd like to add, that the help I get from this list is absolutely great. Having this kind of help is a wonderful thing.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: May 2015 Posts: 11,172 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,172 | I had a body shop owner recommend All Metal to me. I haven't gotten to the point of filler yet, though.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | Things have changed now, Mike. Bondo Lightweight is still very popular and some of the Rage products are also. I think the contest would be between Bondo Lightweight and Rage Gold Premium, but I'll let somebody else decide the winner. I will tell you hardeners have changed. I don't know what they did to them, but it wasn't a good change and I started noticing it about 3 years ago. Today in hot weather it sets really fast and in cold weather it can take a day or more to set. Fiberglass hardener now works the same way and it does take some getting used to. Last winter I did some fiberglass work which took 3 days before it could be sanded and it was mixed right by the book. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2019 Posts: 154 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 154 | Most fillers good, I like to add evercoat plastic honey to filler so I can adjust consistency .This also helps to minimize pinholes,hope this helps. | | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | I had a body shop owner recommend All Metal to me. I haven't gotten to the point of filler yet, though. He's messing with your head. He likely wants you to make a mess of it so he you end up taking it to him to fix. All Metal is an aluminum filler and not a product you want to use, unless you are an expert technician and know exactly why you are using this particular product. Get a good gallon of Evercoat Rage Gold or similar and have a much easier time with it than you ever would with All Metal. | | | | | Joined: May 2015 Posts: 11,172 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,172 | He's messing with your head. He likely wants you to make a mess of it so he you end up taking it to him to fix. All Metal is an aluminum filler and not a product you want to use, unless you are an expert technician and know exactly why you are using this particular product.
Get a good gallon of Evercoat Rage Gold or similar and have a much easier time with it than you ever would with All Metal. Well he won't be getting it to fix if I try that, because he closed his shop. As I mentioned, I haven't gotten to filler yet, so will research more before starting. I do have some experience using filler, but it was about 50 years ago. Thanks
