7 members (Wrenchman, Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, 1 invisible),
52
Mod | | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Anyone ever use em on a mustang II cross member? What were your results? I dont weld so I am thinking of doing this rather than being gouged at the weld shop.
Thanks | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Im not sure i have seen bolt in mounts for a must II set up. Mine are weld in and in my 39 bolt ons would have probably put the motor too far forward. | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | For what the welding shop will likely charge, you can buy a suitable arc or MIG welder. I bought my Century MIG welder from Sam's years ago for a few hundred and I have welded a LOT with it and it still runs fine. I use a situation like yours to justify buying tools. Tools make great christmas presents and Santa will be coming soon. My next purchase will likely be a tube bender from Harbor Freight so I can bend my own exhaust pipes. Not the greatest quality in the world but at just over $100, it will pay for itself in just one job because my local muffler shop will for sure charge me a lot more than $100 to install a dual exhaust system. | | | | | Joined: Apr 2003 Posts: 21 New Guy | | New Guy Joined: Apr 2003 Posts: 21 | I think he might be talking about the bolt in tubular crossmember motor mounts, right? | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I called a welding shop in town, and asked if they could send over a welder.. the owner quoted me $125.00 to weld in the crossmember... the kid showed up and worked on the truck for 6 hours.. welded in the whole front end.. he was supposed to get $45.00 an hour.. but the shop owner wouldnt take any more money... great guy.. I'm going to get my own welder tho.. and do my own work.. I bolted a tubular engine crossover setup in tho.. after test fitting it and drilling in set screws, I took it to a welding shop and they charged me $20.00 to weld the ends on..
| | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Unless you already know how to weld, it's more than getting a "spark" to weld, especially on your truck where there's torque and flex. I know I wouldn't want a novice welding my motor mounts or any critical joints where my or other lives are concern. | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | I actaully was not talking about the tubular type. I have a mustang 2 IFS and I do not think that a tubular xmember will fit in there. I think that RBs obsolete and TCI both make bolt in separate brackets for this. I just wondered if anyone had used them with the mustang 2. | | | | | Joined: Apr 2003 Posts: 8 Member | | Member Joined: Apr 2003 Posts: 8 | Originally posted by In2deep: I actaully was not talking about the tubular type. I have a mustang 2 IFS and I do not think that a tubular xmember will fit in there. I think that RBs obsolete and TCI both make bolt in separate brackets for this. I just wondered if anyone had used them with the mustang 2. I recently bought the Mustang II IFS package from CD..I believe it is bolt on. 4 3/4 bolt pattern, so if you do a rear end swap, check your bolt pattern..let me know how your's turn out.
http://www.clgw.net/~tonyp
