0 members (), 80 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#132201 11/06/2003 11:02 PM
I
I Offline
Anyone ever use em on a mustang II cross member? What were your results? I dont weld so I am thinking of doing this rather than being gouged at the weld shop.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#132202 11/07/2003 6:30 PM
Im not sure i have seen bolt in mounts for a must II set up. Mine are weld in and in my 39 bolt ons would have probably put the motor too far forward.
#132203 11/07/2003 8:38 PM
For what the welding shop will likely charge, you can buy a suitable arc or MIG welder. I bought my Century MIG welder from Sam's years ago for a few hundred and I have welded a LOT with it and it still runs fine. I use a situation like yours to justify buying tools. Tools make great christmas presents and Santa will be coming soon. My next purchase will likely be a tube bender from Harbor Freight so I can bend my own exhaust pipes. Not the greatest quality in the world but at just over $100, it will pay for itself in just one job because my local muffler shop will for sure charge me a lot more than $100 to install a dual exhaust system.
#132204 11/08/2003 6:53 AM
I think he might be talking about the bolt in tubular crossmember motor mounts, right?
#132205 11/10/2003 5:25 AM
I called a welding shop in town, and asked if they could send over a welder.. the owner quoted me $125.00 to weld in the crossmember... the kid showed up and worked on the truck for 6 hours.. welded in the whole front end.. he was supposed to get $45.00 an hour.. but the shop owner wouldnt take any more money... great guy.. I'm going to get my own welder tho.. and do my own work..
I bolted a tubular engine crossover setup in tho.. after test fitting it and drilling in set screws, I took it to a welding shop and they charged me $20.00 to weld the ends on..
Another quality post.
Real Trucks Rattle
#132206 11/10/2003 3:39 PM
Unless you already know how to weld, it's more than getting a "spark" to weld, especially on your truck where there's torque and flex. I know I wouldn't want a novice welding my motor mounts or any critical joints where my or other lives are concern.
#132207 11/11/2003 1:45 AM
I
I Offline
I actaully was not talking about the tubular type. I have a mustang 2 IFS and I do not think that a tubular xmember will fit in there. I think that RBs obsolete and TCI both make bolt in separate brackets for this.
I just wondered if anyone had used them with the mustang 2.
#132208 11/17/2003 5:35 AM
Quote
I recently bought the Mustang II IFS package from CD..I believe it is bolt on. 4 3/4 bolt pattern, so if you do a rear end swap, check your bolt pattern..let me know how your's turn out.
http://www.clgw.net/~tonyp
