0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | Seems like a 235......has no capt. bars,,,,,serial is 9-534847....... NO letter code...... head is xxxx848........
Casting is 3754844 on the flip side of the block is 0 K 21....which I translate as 1960 Novemebr 21st
Clues.....engine had a right hand drive bell housing used with, I beleive, a hydraulic clutch..... have seen those set up in a 60 era Chev van...... starter is solonoid model not a stomper....
Hoping to buy it but can't run on existing stand..... engine is cleaned and painted like lipstick on a pig!!!!!!!!!
Would appreciate comments/suggestions....etc.
PS......could this be a GMC engine .....or a Chev engine fitted in a GMC truck in Canada???????
Bob C. CMP Heaven The Hammond Barn
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GMC engine' SN starts with the displacement, stamped on machined pad aft of distributor, right side, I. e. 228xxxx, thus yours is not GMC engine.
Ed
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | isn't 3754844 an intake manifold casting number? what's the block casting? in Canada many GMC trucks had Chevy engines, and Canadian engine stamps do NOT follow USA patterns. -s
