1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
I have a 1941 1/2 ton, 4 speed, w/GMC 228. I just bought the truck knowing there is a noise from throwout bearing. My exp. is with blue oval A's. I want to get parts ordered before I start job. Any suggestions on bearing, clutch or other parts I should order?
Crusing in the Passing Lane
Depends on how the clutch works now, throw out bearing for sure, clutch and pilot bearings are readily available, so check condition upon disassembly and order as needed.
Ed
Thanks, was planning on that - anything else?
