0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1321613 08/12/2019 8:32 PM
V
V Offline
Is Classic Performance P/S conversion kit a good one to use? We're keeping the original 6 cy eng so need some advice about using their P/S pump and what issues there might be putting that pump on the original 6 cy. as to mounting and pulley alignment. Thanks for any advice!
You might look into EPAS electric power steering. I went that way because all you do is cut a chunk out of your column and place it inline. Stock steering box. no pumps, hoses, pulleys or belts. It has adjustable gain. Just a thought.
EPAS is fairly easy to install but about 4 times the cost. 🛠
It's pricey for sure but since I had to start from scratch and planned on getting all new parts I don't know about 4 times. Mine was $1500 and done. I also have space issues on mine. I also have electric A/C for the same reason. Makes for a clean engine compartment. Just a personal choice.
V
V Offline
Electric A/C like in Tesla and/or another EV brand? That would be interesting to hear about, enlighten us old fogy's, LOL.
Went and searched the unit the OP was referencing. Price was almost $800 so I’ll revise my statement to almost twice as much. My kit for the ‘62 C-10 came from Western Chassis and was $300 w/o the pump and belts.🛠
We just pull the steering unit and the controller out of a Saturn Vue for around a $150 for everything needed. Of course this "everything" doesn't include measuring, welding, mounting, fabricating, etc. They work great and no hoses, pumps, or belts.
Evan
V
V Offline
My biggest concern was how hard to mount the P/S pump on a 216/235 engine? If I had a small block in it that wouldn't be an issue but the OEM 6cyl I didn't have a clue. I guess I was thinking someone had brackets to do it???
The easiest would be to get a generator with the p/s pump mounted on the rear but the are getting pricey and exhaust pipe needs bent to clear the pump. Performance Online has brackets for under $200. Show to be for a 235 but surely a little tweaking would fit them to a 216.
Evan
V
V Offline
thks I'll check with them...
