| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Is Classic Performance P/S conversion kit a good one to use? We're keeping the original 6 cy eng so need some advice about using their P/S pump and what issues there might be putting that pump on the original 6 cy. as to mounting and pulley alignment. Thanks for any advice! | | | | | Joined: Apr 2016 Posts: 1,036 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,036 | You might look into EPAS electric power steering. I went that way because all you do is cut a chunk out of your column and place it inline. Stock steering box. no pumps, hoses, pulleys or belts. It has adjustable gain. Just a thought.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | EPAS is fairly easy to install but about 4 times the cost. ðŸ›
| | | | | Joined: Apr 2016 Posts: 1,036 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,036 | It's pricey for sure but since I had to start from scratch and planned on getting all new parts I don't know about 4 times. Mine was $1500 and done. I also have space issues on mine. I also have electric A/C for the same reason. Makes for a clean engine compartment. Just a personal choice.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Electric A/C like in Tesla and/or another EV brand? That would be interesting to hear about, enlighten us old fogy's, LOL.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Went and searched the unit the OP was referencing. Price was almost $800 so I’ll revise my statement to almost twice as much. My kit for the ‘62 C-10 came from Western Chassis and was $300 w/o the pump and belts.ðŸ›
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We just pull the steering unit and the controller out of a Saturn Vue for around a $150 for everything needed. Of course this "everything" doesn't include measuring, welding, mounting, fabricating, etc. They work great and no hoses, pumps, or belts.
Evan
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | My biggest concern was how hard to mount the P/S pump on a 216/235 engine? If I had a small block in it that wouldn't be an issue but the OEM 6cyl I didn't have a clue. I guess I was thinking someone had brackets to do it??? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The easiest would be to get a generator with the p/s pump mounted on the rear but the are getting pricey and exhaust pipe needs bent to clear the pump. Performance Online has brackets for under $200. Show to be for a 235 but surely a little tweaking would fit them to a 216.
Evan
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | thks I'll check with them... | | |
