8 members (frogfarmer, 52Carl, KEVINSKI, Hotrod Lincoln, Rustnut, Cletus1950, 1955 1 Series, fonz8261), 98 guests, and 2 robots.
Topics128,177
Posts1,057,060
Members48,460
I've got a 70 nova front clip thats looking for a new home.Along with a rearend from the same vehicle.I have a 66 suburban that I'd like to put it in.Will the nova clip be a good choice for the 66 'burb or should I use a different clip as a donor? The 66 has stock suspension with a 12 bolt,drums all around,6 lugger with a 250 and a 4 speed.The nova has front disc's,a stock 12 bolt and had a 250 and a powerglide in it.I've got a 327 with camel hump heads and a turbo 350 a/t from a 89 chevy van with overdrive ready to drop in the 66 after I complete the clip swap.What do you think?
I'm not against sub framing but am wondering why you want to do it to your burb. If it's only for the disc's I wonder if maybe you could find newer truck spindles and disc's to fit. Maybe even do it without needing a spindle change.
My original plan was to look for rotor's and calipers from a '73 to '89 chevy truck or van that would fit the stock 66 spindles.Or spindles,rotors and calipers fom a chevy truck or van.My existing set up is 6 lug drum.I want to go 5 lug,with disc's,power steering with a tilt column.Was I on the right track originally?If I was what year of vehicle should I be hunting down for parts?Any suggestions would be appreciated.The Nova clip I'll probably save for my '55 Buick Century,which may be a better candidate for a subframe swap.Anyone that's completed a drum to disc/tilt column swap on a '66 truck or suburban or subframed a '55 Buick with a Nova clip,I welcome your advice on the subject.
I happen to know that you can slip a 89 Caprice frame under your sub and all you have to change around will be your frame mounts. Well maybe a few other things but not much. The Caprice has same wheel base front to back and side to side. Just more things to consider. grin
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
