I have heard some guys say that they used "Ram's Horn" manifolds; they dump straight down in the middle of the block. The problem is the clearance with the steering box (unless you relocate it to outside the frame).
Log manifolds might work, especially if you could use 2 passenger side manifolds and have one dump towards the front, so you could "cross over" to the othe side where there is more clearance.
You might also consider offsetting your engine 1-1/2" towards the passenger side. Then the Ram's Horn manifolds (or headers, if you so desire) will clear.
I don't know if
Sanderson cast iron block hugger headers will clear; maybe someone else will chime in on this.
Also,
Headers By Ed . They have been around for a while and they sell "make-it-yourself" sets............
