0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Hi all, I think I screwed up big time with my 350 tranny. I bought this 38 Chevy project with a 327/350 combo. The transmission is rebuilt (?) and has never been run since rebuild. The previous owner told me he had put 3 qts. transmission fluid in and I read somewhere that it takes 11 qts. with the torque converter. Since the engine is not running yet I couldn't check the fluid level correctly. Anyway, smart old me thought I would go ahead and add more fluid so when the engine fired up there would be sufficient fluid in the transmission. After adding 3 more qts. I now have fluid running all over my garage floor. It seems to be coming from the area where the kickdown cable goes into the transmission. The dipstick is measuring way over full. What should I have done and more importantly what the heck do I do now? Sorry for the long post but I wanted to give as much info as I could. Thanks for any suggestions and not laughing at my screw up. | | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | let her drain, the fluid is prolly coming out the vent.
you won't be able to fill the trans UNLESS the engine is running(the pump won't pump fluid in to the converter). doesn't sound like a major prob yet, just a messy one
i miss obscene phone calls...
| | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Go to Home Depot and get one of those heavy gage plastic "stucco" mixing pan to catch the fluid. Place it under the transmission and then loosen the pan bolts and let it drain. You'd have to guess-timate how much drained...at least 4 quarts. Retighten the transmission pan, fire the engine up, shift from "drive to neuteral to reverse several times to warm the tranny then check the dipstick. Add accordingly. Good luck. | | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Thanks guys for the responses. It's a relief to know nothing was damaged (except my ego). I will drain out excess fluid then move on to the next screw up. | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | There should not be any fluid leaking out from where the cable goes in the housing. There should be a o ring there. Take the hold down bolt out and lift the cable up a bit and make sure it's there. Trans fluid make a real nice flames  when the exhaust get up to temp. | | | | | Joined: Mar 2004 Posts: 49 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 49 | I think the manuals recomend 7 quarts to start with , you should not have had any leaks. Check your gromet on the dipstick tube ,transmission lines as well as the kickdown cable. You may have to get under it and watch while someone pours in the fluid. | | |
