| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 15 Member | | Member Joined: Jun 2004 Posts: 15 | I stuck a radio/cd player in the Green 71 today, and I'm scratching my head over where to mount the spikkers.
I read Alan Horvath's page, and I like the angled underdash mounts he made... but isn't there a company out there that makes engineered sound systems for pickemup trucks?
I'd like to have some sort of subwoofer under the seat, high frequency tweeters maybe on the dash... but the big problem is where the hell to mount the main power drivers (usually 6x9's on the rear deck if you're thinking Camaro...)
I need sweet sound. Who's been down this road before, and what was the solution?
Gracias
Paul Domeier Green71 | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I was down this road last month helping a friend with his sound system in his 71 P.U. We put tweeters at ear level in the vertical panel of the cab "where the upper seat belt bolt is located". We installed "Mids" in the back panel of the cab below the rear window. The gas tank was relocated to the bed so we had all that room for the bass speaker. In the center of the cab on the back we made up a panel to hold the Amp and Capacitor "I think that's what it was called" and some other goodies. I wanted to install some 12" in the panel but it's not my truck.....he went with one of those Bazooka tubes that sits on the floor and placed it behind the seat. Now on my 70 P.u. I just purchased some 3-way speakers that come in their own enclosure "box" and bolted them to the back of my seat and I was done
Joe
| | | | | Joined: Jun 2004 Posts: 15 Member | | Member Joined: Jun 2004 Posts: 15 | Thanks Joe
I put two Pioneer 6X9's in boxes under the seat facing forward, and two little tweeters up by the sun visors. The fuel tank is still behind the seat, so not very many options for a subwoofer.
It sounds okay... but it could be a whole lot better.
Relocating the tank looks like a pretty complicated mod.
Paul Domeier Green71 | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Look in the links section here on the Stovebolt. There should be a link to LMC which has some options for roof panels and speakers. - (Links link is up at the top of this page  )
| | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | Secret Audio has speakers that mount under the seat and stereo that mounts anywhere that has a remote. Several classic truck accessory places carry them , also are in the ads in Classic Truck magazine.Hope this helps! | | | | | Joined: Jun 2004 Posts: 12 Apprentice | | Apprentice Joined: Jun 2004 Posts: 12 | Hi, I would relocate the 6x9's to the doors (you will have to make a hole thought in the door) then put the 12" where the gas tank was. If you go to Custom Sounds or Alpha Audio (or your local sound system pace, not bestbuy) they will have a box that will fit where the gas tank was. Hope I helped. | | | | | Joined: Jun 2004 Posts: 15 Member | | Member Joined: Jun 2004 Posts: 15 | Secret Audio has some cool stuff!
Thanks for all the suggestions.
Paul Domeier green71 | | |
