| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 10 Member | | Member Joined: Mar 2002 Posts: 10 | I am looking at buying a mustang II crossmember. Complete kit out of budget right now. My question is what year arm control arms can i use if i get a donor disk brake setup. have seen a article uses donor truck setup, but they didn't say what year. any help appricated. | | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | Not sure what you mean by "control arm" , are you refering to the steering arms ? which aren't removable on mustange2/pinto spindles . They are cast as one piece. Most disc brake convertions use which ever bolt patern you want(**** or chevy) rotors and special brackets to mount the calipers .The **** bearings fit the chevy rotors - but do require special seals and spindle nuts . | | | | | Joined: Mar 2002 Posts: 10 Member | | Member Joined: Mar 2002 Posts: 10 | I am talking of a aftermarket MII crossmember not a **** type. the question is which year control arms can be used and if truck control arm from a donor truck can be used. | | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | A MII IS a **** design suspention . **** built the Mustange II from 1974-1978 which is the same as the pinto/bobcat from 1974-1980 . Those are the donar cars that fit the M II crossmembers , there are no trucks that used these parts . | | |
