Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (TPR57C, GrandpasJimmy, ShopRag), 119 guests, and 5 robots.
Topics128,281
Posts1,058,471
Members48,490
#132109 03/29/2002 4:53 AM
I am looking at buying a mustang II crossmember.
Complete kit out of budget right now. My question is what year arm control arms can i use if i get a donor disk brake setup. have seen a article uses donor truck setup, but they didn't say what year. any help appricated.
#132110 03/29/2002 5:22 AM
Not sure what you mean by "control arm" , are you refering to the steering arms ? which aren't removable on mustange2/pinto spindles . They are cast as one piece. Most disc brake convertions use which ever bolt patern you want(**** or chevy) rotors and special brackets to mount the calipers .The **** bearings fit the chevy rotors - but do require special seals and spindle nuts .
#132111 03/29/2002 5:41 AM
I am talking of a aftermarket MII crossmember
not a **** type. the question is which year control arms can be used and if truck control arm
from a donor truck can be used.
#132112 04/09/2002 6:13 AM
A MII IS a **** design suspention . **** built the Mustange II from 1974-1978 which is the same as the pinto/bobcat from 1974-1980 . Those are the donar cars that fit the M II crossmembers , there are no trucks that used these parts .
