| | | Forums66 Topics128,057 Posts1,055,814 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | What is the best header option for a 57 6100 with a small block on front motor mounts? The steering box is conflicting with the manifolds I have and headers I have on hand. Anyone have a list of manifolds and or headers that fit? Thanks guys! | | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | Use a left side exhaust manifold from a 55-57 265 engine. They're available on Ebay frequently for very low prices. It has a front outlet and is made to clear the steering gear. Using ANY kind of header except equal-length tubes from each exhaust port is foolish and does nothing for performance at engine speeds where street-driven engines run. 30-something years of dyno runs we did while building round track engines proved that to me repeatedly. Jerry
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Cast Iron Chevrolet Ram's Horn manifolds with a straight down dump work fine and where what the factory used on TF trucks starting in 1957. Mike B  | | |
