3 members (Leo, Gdads51, 1 invisible),
171
Mod | | | Forums66 Topics128,088 Posts1,055,995 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | I have a Camaro subframe under my 51 and was wanting to replace the power steering box . When I called the local auto parts store they said there was two different ones and one had so many turns ? , so what am I looking for ,a certain ratio? | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Probably either a quick ratio or a normal ratio. And I'm not sure how many turns that is lock to lock. I wonder if it's like the Corvette, where there are two holes. One to make it a quick ratio and one to make it a normal ratio, depending on where you attach the linkage.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | If you go to Mullins or borgensons website I believe they show drawings of the different types of boxes and you may be able to determine which one you have..........Dale
1939 GMC 1953 HD PANHEAD 1930 Chevy 3 window coupe
