0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
I have a Camaro subframe under my 51 and was wanting to replace the power steering box . When I called the local auto parts store they said there was two different ones and one had so many turns ? , so what am I looking for ,a certain ratio?
Probably either a quick ratio or a normal ratio. And I'm not sure how many turns that is lock to lock. I wonder if it's like the Corvette, where there are two holes. One to make it a quick ratio and one to make it a normal ratio, depending on where you attach the linkage.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
If you go to Mullins or borgensons website I believe they show drawings of the different types of boxes and you may be able to determine which one you have..........Dale
1939 GMC
1953 HD PANHEAD
1930 Chevy 3 window coupe
