| | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 6 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 6 | Hi All, I am working on a 1933 Maple Leaf 2 ton (Canadian Chev) and a local machine shop has the motor. It was a basket case sitting in a field and it was bad, but the motor serial number matched the VIN tag. The motor is almost done, but they need replacement shells for the crank main bearings. I understand they are babbit bearings but apparently these are what the babbit is poured into? When I checked the Filling Station website they need you to send in the old shells to be rebabbited. I have been looking locally for some replacement shells with no luck, so I thought I would try the forum. Any leads or help would be greatly appreciated! I understand the motor was only used in 1933 and 34 and not common. It has a block casting number of 836915 and it is a 206/7 Master. Thanks! | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Any machine shop worthy of the name should be able to make things like that. It looks like you need to find a better machinist. Once the rough-poured bearings are in place, you'll still need to line bore them to fit the crankshaft. Can the shop you're dealing with do that? All the poured main bearings I've ever worked with, like Model T and Model A Ford engines, have the Babbit metal poured directly into grooves in the block, using molds designed for that purpose. Jerry
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I receive a magazine called “Hemmings Classic Cars”. This months issue has an article on a guy who restored a 1922 Gray roadster. He used a company called The Babbitt Shop in Fort Edwards, NY. You might find them on the internet.
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 |
| | | | | Joined: Jul 2010 Posts: 6 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 6 | Thanks for all your help. I will check them out and figure out what to do next. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | I have a bearing scraper you can borrow. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | 3-corner file+bench grinder+10 minutes = bearing scraper! Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Also called a three toed (sloth) scraper.
Ed
