6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#1319603 07/28/2019 10:11 PM
Hi folks, my truck is a 53 3100, I6 292, TKO 600, Frankland QC-80 quick change. How should I route my exhaust? I'm running duel and want to exit the rear on each side in the back. I will have split headers on the passenger side of the engine. What is the best way or place to cross one over to the drivers side in back? I also have a Bicknel torque arm supports to deal with. As long as I'm asking dumb questions, I have electric exhaust cutouts. Can I Y those off before the muffler and then Y them back in after the muffler instead of just dumping them under the truck?
mick53 #1319614 07/28/2019 11:33 PM
My bet is that no one knows the answers to your questions site unseen. In fact, I would guess that anyone who follows your posts would more likely contact you for help more than vise versa.
mick53 #1319629 07/29/2019 1:31 AM
Thanks Carl. I don't know if I'm qualified to give advice. I'm working 500 miles from home and all I can do is polish parts and think about stuff. I also need to put a drag radiator and A/C condenser under there somewhere. They are about 15" X 15" and 14" X 17"
mick53 #1319729 07/29/2019 10:23 PM
With old split manifolds we run the head pipe through the gap between the back of the pan and the front of the clutch dust cover. A TKO SIX HUNDRED!!, you can add nitrous and a Whipple set at 18#'s of boost and never phase the tranny.
Evan
mick53 #1319741 07/30/2019 12:46 AM
My little Weiand with 8#'s might be jealous.
