| | | Forums66 Topics128,139 Posts1,056,448 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | 1964 C10, 230c.i., 3 speed manual transmission. We need to locate the rubber bushings or grommets that fits between the two shift rods and the tranny shift levers. Anyone know where these small rubber pieces can be found? Thanks.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | These may work or can be modified. .......and a Long Shot
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I had not even thought of McMaster-Carr. I buy stuff from them all the time. One of my treasures is their catalog of which I have several. One of the best references for ‘what’s this do-dad called, and where can I get it’. I found the shift rod bushings at Ecklers for a 64 Bel Air. They should fit. Thanks for the info.
