2 members (Johnnydog, 78buckshot), 95 guests, and 2 robots.
Topics128,060
Posts1,055,832
#1319230 07/25/2019 9:40 PM
Good day, Gents.
I've just about finished this project. Started it 6? years ago and derailed for a time with cancer which slowed things down a lot. But, finally I am into the short rows.
The truck is not really shiftless, but when shifting to "Granny" or 3rd, the shifter knob bangs into the dash. In 1st, it is prevented from fully engaging, other than that, it is just hazardous to my knuckles. Any possibility for adjustment? or is bending the shifter the answer. Anyone else encountered this? Any suggestions appreciated and seriously considered. Thanks in advance for your experience. Will post some new pictures when I find new host.
You don’t say if the transmission is original to the truck. It sounds to me like a torch is the answer if no adjustment is found.🛠
Good evening J.
The truck is all original. You are probably right...Not being a smith, unsure of how torch will affect the metal and how much heat will be needed. Machinist friend suggested this evening that a 3 point fixture with hydraulic jack might work. There is a visible bow in the upper section of the shift rod. Since he is willing to fabricate the fixture, will probably try it. Maybe with additional application of heat.. may be the answer.
I have a shop manual, but as is usually the case, I can't find it; even though I have used it in the last month.
Thanks again for input.
If you want to add pictures, press the "Use Full Editor" button at the bottom of the "Quick Reply" window. Then look for the "Attachment Manager"
link at the bottom left of the new window. You can paste or drag and drop photos directly to your post.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
A fixture and a jack would require no heat.🛠 This situation probably comes from many years of banging the shifter towards the dash instead of gently moving it forward.
Also possible not original transmission or shifter stick at this point.
Bend it cold as first preference, or hot if necessary.
1952 Chevrolet 3800 pickup
---All pictures---
Thanks to all for advice. Poor folks have poor ways - piece of 2x4, length of chain and small bottle jack. A few awkward moments trying to get it all in place while pumping the jack..now have about 2 inches of clearance with tranny in granny between knob and ash tray .
Sweet sounds like u nailed it. Dont smoke long cigars...…...lol
Mainly just checking out the add files feature but also wanted to post pic of truck and the "shift lever adjustment tool.
huck's '46
Sweet ride, nice work!
Dan
Mac :{)
Nice truck and shifter adjustment tool. If theres a will, theres a way.
62401
Nothing redneck about that fix! That was slick, if not also elegant. I may have to use that for a Tech Tip, if you don't mind.
Well done and thanks for sharing!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
