1 members (Bill Hanlon), 197 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
#1318989 07/23/2019 7:36 PM
On a 1958 1/2 ton with a 283 and a Rochester down draft, 2 barrel, carb. Where is the vacuum port supposed to be so one can attach a vacuum gauge to adjust the mixture?
3B Offline
Hy GMCAMARO, If I am remembering correctly there should be a port on the back of the carburetor down near the intake manifold, I think it is a 1/4" pipe port, hope that helps.
Most of the intake manifolds have a port about halfway between the carburetor and the distributor. That one has full manifold vacuum and also serves as a connecting point for a PCV valve, power brake booster, etc.
GMCAMARO #1319124 07/24/2019 10:51 PM
This is interesting, behind the carb near the manifold was 1/2" bolt. I have no vacuum advance and looks like where it goes. Then I remembered a stud with a hole in it, holding down the carb. When I looked in the assembly manual and repair manual I could find no information. The net has shown me these were primarily for cars. Either I have the wrong manifold or the factory was not consistent and mine got the stud.
